Log/lin pot A/B suffixes & prefixes
Discussion in 'Electronic Repair' started by N Cook, May 10, 2007.
  1. N Cook
    N Cook Guest
    Does anyone know of any standard or authorative source for such
    designations.
    eg
    50KA - lin ?
    50KB- log ?
    50KAB - lin/log , semilog?
    50KBA - log/lin ?
    and does a B prefix mean a centre pick off fourth terminal, or 1/3&2/3, or
    any fixed track tap terminal or what if anything a B prefix means. ?
    And while at it any other letter designations eg for cosine track, or even
    wire/wound etc
  2. Ron(UK)
    Ron(UK) Guest
    I think it`s A = lin, B = log except when it isn`t ;)
    the marking conventions changed some time ago
    http://sound.westhost.com/pots.htm#markings
    Ron(UK)
  3. Ron(UK)
    Ron(UK) Guest
    No no, it`s part of a wonderful resources site ESP which contains a
    huge amount of useful info http://sound.westhost.com/
    I thought that I`d put a attribution to the site just before my header,
    but it seems to have gone awol.
    Ron(UK)
  4. Eeyore
    Eeyore Guest
    A = linear (European) or Audio taper (Japanese).
    B = 'log' taper (European) or linear (Japanese)
    Graham
  5. Eeyore
    Eeyore Guest
    There are no meaningful conventions except that C universally means 'reverse log'.
    Graham
  6. N Cook
    N Cook Guest
    so its a matter of ignoring everything other than the likes of 50K and
    measuring ohms at 1/4,1/2,3/4 and full track
  7. Ron(UK)
    Ron(UK) Guest
    connecting the pot to an analogue meter and sweeping from end to end
    will show whether it`s log or lin.
    Ron(UK)
  8. Eeyore
    Eeyore Guest
    What does the resistance value have to do with it ?
    1/2 rotation only. Most of the tapers you're likely to find in audio are
    typically specified @ 50% rotation as a percentage of 100% resistance. Audio and
    reverse log are usually 15% for example (depending which end you're measuring
    from) although I have used semi-specials such as 5% reverse log for mic amp gain
    pots.
    Graham
  9. You don't even need to go that far. Set to approx 1/2 travel and measure
    one side. Linear will be near 50% - log very much not.
