Loewe TV.
Discussion in 'Hobby Electronics' started by John Ely, Feb 16, 2005.
  1. John Ely
    John Ely Guest
    Hello To All,
    I have a Loewe Profil 3272 (recently acquired) how do I
    get the back off it.
    Thanks John Ely
  2. John Ely
    John Ely Guest
    Hi Joe,
    Thanks for the reply,I had a close look at the plastic heads they
    have no slot in them, are they likely to be plugs on top of the screws,this
    set may have not been opened previously.
    Cheers John
  3. John Ely
    John Ely Guest
    I'll give them a call.
  4. Allan
    Allan Guest
    And please let us know..!!
  5. John Ely
    John Ely Guest
    Hello To All,
    I have obtained a copy of the service manual, the plastic
    plugs on the four corners of the back do nothing , to remove the back -
    remove the three screws from the panel with the two scart sockets , remove
    the two screws from the bottom edge of the back , underneath at each corner
    , on the top edge of the back where it joins the front case there are two
    small slots ,one each side, insert screwdriver and push down to release
    plastic clips, back comes off.
    Cheers John Ely.
