Ok, I'll assume you followed my instructions for removing boards to get at the input amplifier.
If the buttons don't have any effect, then you have broader problems. My first check would be the power supply.
Do you have a multimeter, and how confident are you in its use?
Do you have access to a clamp on AC ammeter?
First, check that the voltage has been set correctly. If you remove the power plug and open the sliding plastic cover, you should be able to see the voltage setting on a small board under the fuse. If you need to charge this, pull the board out (it can be very stiff) and rotate/flip it so your mains voltage appears the right way up after you slide it back in.
The next check is a sniff test. When powered on, do you smell any acrid odour coming from the transformer? This is a clear indication of a shorted power supply.
There are several wires leading from the transformer to the main board. After removing any cable tie there is on it, you can use a clamp on AC ammeter to measure the current. From memory you should expect a few hundred mA, perhaps less with the 2 boards removed.
The next step is to measure the voltage on various ICs on the board.
There are a number of 8 pin ICs with part numbers like LM711. If you google the part you can find a datasheet that will show you the +ve and -ve pins. With your meter on a voltage range, and the black lead held against the metal case, the +ve pin should read close to +18V, and the -ve pin should read close to -18V.
There are other ICs with part numbers like 74HCxx or 74Cxx, or maybe 74LSxx. Again, Google these for a datasheet and find the power supply pins the ground (or Vdd) pins will be at 0V compared to the case, and the Vcc, or Vdd pins will probably be close to 5V.
