M
Mac
I live near several strong HDTV broadcasters, but for some reason, in one
room in my house (the one with the TV, unfortunately) I get very poor
reception. This is true for regular TV, too. The transmitters for regular
TV are in the same place as the HDTV ones.
I made a simple folded dipole antenna, and with it I get two HDTV
stations. With store bought antennas, I get nothing, so I guess the folded
dipole is reasonably effective. For the moment, all the stations are in
the UHF, so having a relatively narrow band antenna is OK, I think.
It seems like the easiest next solution is to try a low noise amplifier
between the antenna and the TV. So my question is this: Is there a simple
and possibly worthwhile way to make a LNA which can span the television
broadcast range, from 50-800 MHz. Should I just by a cheapo amp from Radio
Shack and be done with it? I have pretty much ruled out normal op-amps,
because the fast ones aren't all that low noise, and they don't cover all
the way up to 800 MHz. (If I'm wrong, let me know, by the way.)
But it seems that a single transistor set up as a common-emitter amp might
do the job if it is biased right. How hard would such a circuit be to get
right without using signal generators and network or spectrum analyzers? I
have access to those at work, but I'm pretty busy, and don't really have
time to fool around with extracurricular activities.
If this is workable, then maybe someone could recommend a specific
transistor, preferably one stocked by digikey, since I will be ordering
some other stuff from them soon anyway.
best regards,
Mac
best regards,
Mac
