LMC6442 substitution
Discussion in 'Datasheets, Manuals and Component Identification' started by jcurrie, Mar 4, 2011.
  1. jcurrie
    jcurrie
    128
    Feb 22, 2011
    i have a circuit that uses a LMC6442 the closest thing i can fine localy is a LM358 from my limited experience it looks like a valid sub , it this a usable sub?
    jim
  2. davenn
    davenn Moderator
    13,657
    1,888
    The LMC6442 has a substantially lower power requirement, otherwise they are pretty close. So it would really depend on the specific cct you were using it in ... which is ?
    cheers
  3. jcurrie
    jcurrie
    128
    Feb 22, 2011
    using it on a sawthooh gen to ramp a led up to full brightness then back down to off repeating it at about 2 sec i9nterrval.
    jim
  4. (*steve*)
    25,412
    2,780
    That's very low speed, so bandwidth (which is often linked to quiescent current) is unlikely to be an issue.
    Bear in mind I have not looked at the specs to compare these.
    If you're sinking or sourcing significant current from the output, or require a particularly large input or output swing then you should look carefully at the specs, otherwise it may not be critical.
Similar Threads
Loading...
