LM7805CT Heating up
Discussion in 'General Electronics Discussion' started by Supercap2F, Apr 2, 2014.
  1. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    Hi Everyone!
    I have been working on a project that uses a inkjet slider thingy (see photos). It slides the thing that held the inkjet cartridge back and forth when you push a switch. And it has a switch on ether side so when the inkjet cartridge holder thingy comes to the edge it stops the motor to keep it from stalling. Once I have finished this part of it I am going to attached another one just like it sideways on the setup.
    If you do not understand what I just said thats ok. What the problem is is that the LM7805CT voltage regulator is getting very hot after about 10 minutes of use. I do not just mean warm, I mean HOT! I am not pushing any limits that I know of. I'm using a 9VDC power supply (one of those black plug-it-in-to-the-wall things). It's rated at 700mA. I measured it and my meter said it was putting out 12VDC. But that is still lower then the 35VDC max the LM7805CT has. I attached the schematic for the project and a photo of how I have it solder together.
    More photos are available on request. The last photo is of what I plan to do with it.
    Dan:)
  2. kpatz
    kpatz
    329
    88
    Feb 24, 2014
    You'll need a heatsink on the 7805. It's a linear regulator meaning it works like a resistor to reduce the voltage, and the extra energy is dissipated as heat. You'll need a decent sized heatsink to keep the 7805 from overheating.
    How much current does your device draw when operating? Let's say it's 500 mA (1/2 amp). If your power supply is putting out 12V, the 7805 has to drop 7 of those volts to get 5V. 7 volts * 0.5 amps = 3.5 watts of heat it has to dissipate.
    Some ways to reduce the heat generated: use a lower voltage adapter, such as one that actually puts out 9V instead of 12, or use a switching regulator instead of a linear one.
    Lastly, your schematic doesn't show decoupling capacitors with the 7805. They're recommended to keep the regulator stable. The datasheets show a 0.33uf cap from input to ground and a 0.1uf cap across output and ground. A larger cap(s) are a good idea in parallel with the smaller ones, such as 10-100uF.
  3. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    I have a heat sink that is about 3 times as large as the one on it now that I will try.
    I will post some updates when I get every thing hooked up like you said.
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Another really good answer kpatz! I'm glad we have you on board :)
  5. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    Update time! I found a easer way to do it (no 7805). The only reason I did it that way it the schematic in post #1, is because I did not have the right relays. :p
    Dan
