I am a student (14 years old) and I am trying to make a battery monitor using the LM3914 IC. However, at the moment in my circuit diagram the signal source and reference voltage come from the same power supply (the reference voltage is supply by a voltage divider as display in the datasheet and the signal voltage comes directly from the battery as in the datasheet). Is this correct or do I need the voltages to comes come from two separate supplies, the signal voltage from the battery I am measuring the voltage of and the reference voltage from a constant power supply?
Thank you.
Thank you.
