LM386 Spice model
Discussion in 'Electronic Basics' started by [email protected], Mar 30, 2005.
  1. Guest
    Ive tried google. But could not locate the spice model for an LM386.
    Can someone help?
    thanks
  2. Guest
    I got this one from somewhere , can't remember where.
    Can't vouch for its accuracy.. , seems to be ok.
    *lm386 subcircuit model follows:
    * IC pins: 2 3 7 1 8 5 6 4
    ..subckt lm386 inn inp byp g1 g8 out vs gnd
    * input emitter-follower buffers:
    q1 gnd inn 10011 ddpnp
    r1 inn gnd 50k
    q2 gnd inp 10012 ddpnp
    r2 inp gnd 50k
    * differential input stage, gain-setting
    * resistors, and internal feedback resistor:
    q3 10013 10011 10008 ddpnp
    q4 10014 10012 g1 ddpnp
    r3 vs byp 15k
    r4 byp 10008 15k
    r5 10008 g8 150
    r6 g8 g1 1.35k
    r7 g1 out 15k
    * input stage current mirror:
    q5 10013 10013 gnd ddnpn
    q6 10014 10013 gnd ddnpn
    * voltage gain stage & rolloff cap:
    q7 10017 10014 gnd ddnpn
    c1 10014 10017 15pf
    * current mirror source for gain stage:
    i1 10002 vs dc 5m
    q8 10004 10002 vs ddpnp
    q9 10002 10002 vs ddpnp
    * Sziklai-connected push-pull output stage:
    q10 10018 10017 out ddpnp
    q11 10004 10004 10009 ddnpn 100
    q12 10009 10009 10017 ddnpn 100
    q13 vs 10004 out ddnpn 100
    q14 out 10018 gnd ddnpn 100
    * generic transistor models generated
    * with MicroSim's PARTs utility, using
    * default parameters except Bf:
    ..model ddnpn NPN(Is=10f Xti=3 Eg=1.11 Vaf=100
    + Bf=400 Ise=0 Ne=1.5 Ikf=0 Nk=.5 Xtb=1.5 Var=100
    + Br=1 Isc=0 Nc=2 Ikr=0 Rc=0 Cjc=2p Mjc=.3333
    + Vjc=.75 Fc=.5 Cje=5p Mje=.3333 Vje=.75 Tr=10n
    + Tf=1n Itf=1 Xtf=0 Vtf=10)
    ..model ddpnp PNP(Is=10f Xti=3 Eg=1.11 Vaf=100
    + Bf=200 Ise=0 Ne=1.5 Ikf=0 Nk=.5 Xtb=1.5 Var=100
    ..ends
    *----------end of subcircuit model-----------
    Cheers
    Rob
  3. Richard
    Richard Guest
  4. larek
    larek Guest
    It appears to be the one created by Dave Dilatush, with the header cu
    off.
    It was orginaly posted to:
    http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&selm=3qfqhe$
    With its most of its problems listed.
    This message was sent using the sci.electronics.basics web interface o
    www.Electronics-Related.com
