LM386 max input spec is 400mV?
B
Bill Bowden
Data sheet for the LM386 audio amp shows a maximum input limit at +/-
400mV.
What happens if you tie the input to a pot and the pot is coupled
through a cap to a signal sitting at 5 volts DC?
If the pot is set maximum when power is applied, the cap may pass a
voltage greater than 400mV as it charges.
Is this a bad thing?
-Bill
John Popelish
400mV.
If you change the pot position fast enough, or the pot
doesn't have perfect contact the whole time, yes, it is a
bad thing. It slaps the output of the amplifier around.
A much better way (if one end of the pot is at ground, and
there is DC across its resistance), if you can arrange it,
is to put the cap at the signal input end of the pot, and
connect the wiper directly to the LM386. That way, moving
the wiper does not change the average voltage going in to
the amplifier.
E
Eeyore
400mV.
Why are you using such a miserable device ?
Graham
B
Bill Bowden
Graham
Well, because it provides less than 0.3% THD, has an idle current of
less than 5mA, provides 5 volt p-p signal into 8 ohms using a 7.2 volt
lithium battery, and the gain is internally set to 20 so that minimal
extra parts are required.
Do you have a better solution?
-Bill
M
maxfoo
-Bill
LM4877 More output power, better THD and PSRR.
M
Michael Black
And you can get a 386 in single quantities just about anywhere. If
you can't extract it from all kinds of consumer equipment that is
using them already (lots of modems that nobody wants, for instance, will
have a 386).
If he needed a better solution, as in better specs, likely he'd be
pursuing it. But I'd say the 386 is still valid.
Michael
B
Bill Bowden
the amplifier.
One end of the pot is at ground and the wiper connects directly to the
LM386 input. The other end of the pot connects to a capacitor which is
tied to the signal riding on a DC offset. So there is no DC voltage
across the pot. My concern was when power is applied and the wioer of
the pot is set at maximum (connected to the cap), a DC voltage will be
momentarially applied to the input as the capacitor charges during
power-on. It would just be a short spike of a few milliseconds.
The gain is 20, and I need 5 volts p-p out, so the normal input should
not exceed 150mV peak.
Do you think a Schottky diode could be used from ground to the input
to limit the signal to around 300mV? Or is that necessary?
-Bill
John Popelish
Yes. There will be a power up transient. If you use a
capacitor on the bypass terminal, it will also produce an
output transient at power up. If you couple the speaker to
the output with a capacitor, and the other end of the
speaker connects to one side of the supply, you will get a
power up transient. (You can eliminate most of that by
putting two equal capacitors in series across the supply,
and tie the speaker between the middle node and the output)
You might get the combination of these transients to
partially cancel if you work at it.
Since the +-0.4 input volts is the absolute maximum, this is
probably a good idea. I can see how the -0.4 volts might
cause problems, but I can't understand how exceeding +0.4
volts does anything except saturate the output.
E
Eeyore
Wow ! You knocked me sideways. Is it really truly that BAD ?
has an idle current of less than 5mA, provides 5 volt p-p signal into 8 ohms
using a 7.2 volt lithium battery,
What's the significance of lithium ?
and the gain is internally set to 20 so that minimal extra parts are required.
You mean an extra 1/4W resistor ? Do you *want* or *need* a gain of 20 ?
Any modern power amp IC.
Graham
E
Eeyore
Because clots keep designing the useless pices of shit into gear because they're
incapable of looking beyond the ends of their noses to the open page of a modern
databook.
The LM386 is *notorious* for ultrasonic oscillation btw. It's noisy as hell and
distorts like a good 'un.
Graham
B
lithium battery,
You don't get 0.3% THD at 5Vp-p output,
the THD is over 10% at that output level.
Look at the graph in the datasheet, the THD shoots
up above 0.2watt (about 1.2v in 8ohm).
The LM386 is a horrid amplifier.
400mV.
-Bill
There is some confusion in your question. "you tie the input
of the pot" to what? The signal cannot be 5V DC, signals are
AC by definition. Please clarify what you mean, even post
a circuit diagram.
B
Bill Bowden
a circuit diagram.
You tie the input (of the 386) to a pot (the wiper).
One side of the pot is at ground and the other side is tied to a cap,
The other side of the cap connects to the input signal which is
sitting at a positive voltage.
Very standard setup. How else would you do it?
-Bill
