ian field said:
Something I want to build with an OP-amp needs the "ground sensing" inputs
like the 358 but needs power bandwidth up to about 50kHz, and preferably
better O/P drive capability - any suggestions?
"Ground sensing"? I think what you mean is that the input common mode range
extends to the negative supply rail (that is, to "ground" in a single supply
scenario), and the output also can reach the negative rail. That's what the
manufacturers typically mean when they call something a "single supply"
opamp.
There are plenty of single-supply opamps out there that can do this, as well
as plenty of "rail to rail" opamps that can reach both the negative and the
positive supply. Just use the parametric search functions for the web site
of whatever manufacturer you're fond of.
If you go for a rail-to-rail opamp as opposed to a single-supply opamp, be
aware that they can sometimes be less stable than "traditional" opamps. If
sensing to the negative rail is all you need, you're probably better off
with single-supply.
