LM3478 design gets insanely hot
Discussion in 'General Electronics' started by Henrik [7182], Jul 29, 2008.
  1. Joerg
    Joerg Guest
    Aquavit isn't sweet. But it has to be served ice cold and ideally the
    glassed should be chilled to where ice crystals form when you take them
    out. Just make sure you don't have to drive anymore that day.
  2. JosephKK
    JosephKK Guest
    Most are not. The Juibilamus aperitif variety is. It is kind of like
    the difference between Scotch and Drambuie.
  3. neon
    neon
    1,325
    Oct 21, 2006
    You still don't get it 15v to 32v @1A =17w use a pre-regultor of 18v if you must run from a wild input range 15v 32v. the same applies to 120vac I used a 90v regulator to compensate for line drop typical on airplanes power sources. eficiency goes to hell but it works.
