LM3429 flashing LED driver?
eem2am
Aug 3, 2009
429
Aug 3, 2009
429
We are doing a ~2Hz flashing LED driver
vin=12v
vout= ~33v (max)
iled = 0.45 (bit this is in the on state, oviously zero in off state)
buckboost
926khz
We use LM3429 controller.
We are flashing the leds and want them to come back on smoothly each time.
Can we do this by shorting the comp pin to ground temporarily before flashing the leds back on?
LM3429:
http://www.ti.com/general/docs/lit/getlite...29&fileType=pdf
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
What do you mean by "come on smoothly"?
I doubt that shorting the pins of a comparator to ground is a good idea.
Your link is broken.
eem2am
Aug 3, 2009
429
Aug 3, 2009
429
by coming on smoothly i mean no over shooting in the inductor current.
For example, shorting the comp pin of the ucc28c43 to ground affects a soft start, ...is it the same with the LM3429.
For the ucc28c43, adding a soft start circuit is done via the comp pin, as many of the old unitrode app notes testify
Harald Kapp
13,722
13,722
Have a look at the LM3429's datasheet.
Figure 5 shows an anlog dimmming circuit. You can use this to simulate a soft start. Read also the text, it describes various dimming methods.
