B
Bill Stock
I built a temperature sensor based on the LM317 current loop in the LM34
docs. I went this route, as the sensor is about 100 feet from the input
device. But the temp is jumping up and down by a couple of degrees all the
time (noise?). I went with the current loop due to the length of the wire to
the sensor/317. The one note I did read in the LM317 docs suggested tieing
VOut to the case. I haven't tried this yet.
Has anyone else used this circuit? any suggestions? I'd also appreciate any
help with the math (resistance values) if possible.
