LM311
Discussion in 'Electronic Components' started by Arnaud, Apr 17, 2004.
  1. Arnaud
    Arnaud Guest
    Quelle sont les avantages du LM311 (qui est a une sortie à collecteur
    ouvert) par rapport par exemple au LM311 ?
  2. The LM311 has no advantages over the LM311 :)
    If you mean compared to an op-amp, the LM311 can switch much faster.
  3. maxfoo
    maxfoo Guest
    Translation:
    Le LM311 n'a aucun avantage par rapport au LM311:)
    Si vous moyen comparé à un op-ampère, le LM311 pouvez commuter beaucoup plus
    rapidement.
    Remove "HeadFromButt", before replying by email.
  4. I'm suspicious of "op-ampère" as a translation of opamp.
    But in any event, I think the original poster was wondering about the
    advantages of an open collector comparator, as opposed to the kind with a
    push-pull output like that of an opamp. One advantage is you can put many
    open-collector outputs in parallel, to get a logical "or" of all the
    outputs. There are plenty others - just look at comparator circuits.
  5. I gather that was translated by machine?
    "If you average compared to op-ampere"---?
    "Si vous voulez dire, par rapport a un amplificateur operationnel..."
    perhaps!
