B
bos
I'm having an LM311-oscillator (found on google) that I'm going to use
in my own circuit later on. But before doing this I need to learn how
it works. Been looking at the schematic for two days now trying to
figure things out but fail miserabely, so I'm asking for a hand here.
Here's the schematic:
http://bos.hack.org/hacks/electronics/311.png
I'm not skilled at analog electronics, but I really want to learn
what's happening here.
What I know is that R2/R3 is a voltage divider. R4 is some sort of
feedback (no idea what it does) and since it's connected to the
voltage divider it confuses me even more. No clue what R5 does. For R2-
R5, I don't know where to start solving or what I'm looking for.
Furthermore, I know R1/C1 is a lowpass-filter, and I know the cut off-
frequency for this kind of filter is f = 1 / sqrt(RC * 2pi). Solving f
gives 1.53Hz, but this value is of no use to me since I don't know
what it tells me. I'm guessing that any signal below 1.53Hz goes into
the negative input of the opamp. But this is just a weak guess and it
doesn't tell me much.
Other than this, I'm completely lost. My goal for this circuit is to
manually calculate the frequency at the opamp-output (pin 7), I only
manage to identify the LP-filter and the voltage divider (which
probably isn't a voltage divider because of R4).
Can anyone help me out? Where do I start in circuits like these? Is
there any particular order you have to calculate / solve things?
