LM2917 - to measure between 0 to 10Hz
Discussion in 'General Electronics Discussion' started by Bel_Esprit, Nov 7, 2012.
  1. Bel_Esprit
    Bel_Esprit
    Nov 7, 2012
    If anyone could help i would gladly appreciate it,
    I am trying to design LM2917 to rotor speed of a turbine and wind speed, using one of the AC lines from a three phase
    So for the rotor speed i need to measure between 0 and 600rpm, i looked at couple of LM2917 voltage to frequency circuit, but they output high Hz/V,
    What can i used to calculate the resistor or capacitor that i need to design a LM2917 that can measure between 0 to 10Hz? Can anyone point me to the direction with formulae or just let me know what capacitor or resistors i need and pin configurations? would really appreciate it.
    Is it also maybe to get the frequency (then rotor speed) directly using a National Instrument DAQ Card, by just stepping down the voltage using a voltage divider?
  2. (*steve*)
    25,448
    2,809
    Look at the datasheet. See page 7. Bottom left corner.
    Aren't datasheets wonderful!
