Okay EinarA you are a genius! Thank you everyone for your help!
IT WORKED!!!!!!!!
Both the LM2917 and LM2907 worked with the corrected timing parts!
The .1uF capacitor in series with the input is absolutely essential! What does it do? The pull down/pull up resistor (11K at pin one to ground)- I am sure helps but is not required- is this to force the logic state?. Same with the .1uF capacitor from pins 6 to 8- not required but likely helpful? What is this capacitor designed to do? Interestingly, the LED flickers without the 222 ohm resistors in series with the positive 9 volts at the same frequency...
The circuit threshold is stable at 10.85 Hz. It flashes from 10.2 to 10.85.
I do not understand why a 47K resistor (I didn't have a 50), and flipping the capacitors worked though as the answer is the same 10 Hz with the 5K resistor and 10uF capacitor?
Is it because C2 must be larger than C1 with that other formula you got from that book? We are only at 10C1 so would 50C1 be more stable?
Thank you! Thank you! Thank you!
