LM-377N ???????
Discussion in 'Electronic Components' started by spock, Dec 25, 2004.
  1. spock
    spock Guest
    Hello Folks
    I have need for some (2 or 3) LM-377N dual audio amps for a repair I have.
    Can you help
    Is there a equivalent?
    Thanks in advance.
    Lee.
  2. Amstereoguy
    Amstereoguy Guest
    LM1877N
    What component uses the LM377?
  3. spock
    spock Guest
    Thanks I just found a picture of a revised circuit board and it uses the
    LM1877N.
    Thanks BTW it is used in a high end Communications receiver.
    I need to find a equivalent for a UA757 it is op amp used as a IF amp it has
    two per chip 14pin can not find a data sheet.
  4. Mark Hooks
    Mark Hooks Guest
    Pacman arcade games use this part.
    Mark
  5. Guest
    I located a guy who has these parts.
    He can be contacted at this email.
    He has very good prices without any minimums
