lm 350 problem
Discussion in 'Electronic Basics' started by lerameur, Jan 15, 2007.
  1. lerameur
    lerameur Guest
    hello,
    I wanted to know if by using two lm350 in parallel, I would be able to
    use 2 * 3amp ?
    One of them usually regulated a max of 3 amp.
    I also, I heard i could add a transistor in parallel to one LM, where
    would be the base and collector hooked to , assuming (NPN) the emitter
    is at the output.
    thanks
    ken
  2. Phil Allison
    Phil Allison Guest
    ** Groper Alert !
    ** Forget paralleling - go buy an LM338K, it does up to 6 amp.
    ** Bad idea.
    ....... Phil
  3. lerameur
    lerameur Guest
    Good thank you
    ken
  4. Phil Allison
    Phil Allison Guest
    "lerameur"
    ** Cripes - a satisfied customer ....
    The usual Basil Fawlty comment implied !!
    ....... Phil
