LM 35
vick5821
Jan 22, 2012
700
Jan 22, 2012
700
In my project, where I have to demo, I will put a rubbish there and when start demo, I will burn it, then the PIR sensor will detect ?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
That won't require much accuracy :)
vick5821
Jan 22, 2012
700
Jan 22, 2012
700
If I put several LM 35 sensor in a small enclosed area, possible to make the LM 35 sense the raise in temperature by the heat of the combustion ?
(*steve*)
25,510
25,510
Only if you light a fire under them.
(That means NO)
edit: actually, it means yes if you literally place them in an enclosure that is heated by the fire. But unless they are actually heated by the fire, they won't detect anything.
On the other hand, something that can detect the black body radiation from the fire can do so at a distance.
