flippineck
- Sep 8, 2013
- 358
- Joined
- Sep 8, 2013
- Messages
- 358
Looking for a UK supplier for the following:
..or something directly equivalent. This is to repair a Milwaukee V28 cordless drill battery pack.
Any ideas or suggestions where I might find a supplier would be gratefully received.
Code:
Lithium-ion Moli IMR-26700A 2900mAh 3.8V Cylindrical High Power Cells Specifications
Manganese dioxide based Li-ion battery cell
2900mAh, 3.8V, max 40A discharge
A number of safety features were designed into the IMR-26700A cell, including thermal interrupt, tear-away tab and vent that relief pressure and prevent runaway overheating and outgassing. In addition, it's 40A maximum discharge provides stable 13C discharge, an attribute from the spinel structure of LiMnO2.
Model Number: IMR-26700A
Type: LiMnO2
Nominal Voltage: 3.8 V
Nominal Capacity: 2900 mAh
Energy: 11 Wh
Size (mm): 26.4 x 70 mm
Weight: 101 grams
Energy Density (Volumetric): 285 Wh/l
Energy Density (Gravimetric): 110 Wh/kg
Operating Voltage: 4.2 V to 2.5 V
Maximum Discharge: 40 A
