A
AJ
Hi All,
I am using a Lithium Ion battery, the Sanyo UF103450P, in a back-up
application where it is nearly never discharged and topped up once every
couple of months when it needs it (dues to self discharge)... My question
concerns the operating temperature. Every now and then the temperature can
creep up to 45C and during the summer, on hot days I expect it may get a
little warmer and I worry about what would happen if the temperature exceeds
60C, its maximum rated temperature during discharge (for some reason it
only has a 50C rated storage temperature?). Is it likely to be unsafe or
will it just shorten the life of the battery over the long term? I monitor
the temperature during charge/discharge, so am only worried about it during
when it is sitting idle.
Any comments are as always, greatly appreciated...
Best regards,
AJ
Best regards,
AJ
