LISN
Discussion in 'Electronic Design' started by Terry Given, Mar 6, 2007.
  1. Terry Given
    Terry Given Guest
    Hi All,
    I need to get a (cheap) 230V <= 16A LISN, to do some pre-compliance
    tests. Any ideas where? doesnt have to be new, I just dont want to have
    to roll my own.
    Cheers
    Terry
  2. Paul Mathews
    Paul Mathews Guest
    They very occasionally turn up on auction sites and usually go for
    good money. However, making your own can be easy and quick. Try
    googling for Keith Armstrong's EMI pages, Cherry Clough Associates. He
    gives construction details for a very nice unit. Also recommended: add
    a Common Mode Diff Mode splitter, easily made from a pulse
    transformer.
    Paul Mathews
  3. Eeyore
    Eeyore Guest
    I did once see a circuit for one. Probably in an IEC document. It didn't look
    that tricky.
    Graham
  4. Barry Lennox
    Barry Lennox Guest
    I built one from Keith Armstrong's EMI pages, I believe it's an exact
    copy out of EN 6xxxxx something. Anyway, they are pretty simple and
    it works well enough, I cannot see any difference between it's
    performance and a $$$$$ commercial unit.
    Barry
  5. Terry Given
    Terry Given Guest
    Thanks for the pointers. I've been googling, but havent found the
    relevant bits yet (and my f*****g internet connection is playing up
    again). Do you have a link?
    Cheers
    Terry
  6. Terry Given
    Terry Given Guest
  7. Terry Given
    Terry Given Guest
    Right, thats the DIY LISN built then. 30m of 4mm^2 wire cost twice as
    much as the steel enclosure, which I bought from RS!
    and FWIW I'm not making a DIY CM & DM splitter - I will use a couple of
    combiners/splitters from minicircuits:
    ZMSC-2-2 0 degrees
    ZMSCJ-2-2 180 degrees
    much better response, and they are about US$60 each.
    thanks once more for the link.
    Cheers
    Terry
  8. Paul Mathews
    Paul Mathews Guest
    For DM/CM splitter, the first time, I used same Minicircuits modules
    you identified. Very good. 2nd time around, I used the equivalent
    Minicircuits circuit board mount modules. Same performance at about
    1/3 the cost. Third time, I used a Pulse Engrg gate drive transformer:
    slightly better performance at 1/6th the cost.
    Paul Mathews
  9. Barry Lennox
    Barry Lennox Guest
    On 15 Mar 2007 07:49:26 -0700, "Paul Mathews" <>
    wrote:
    --snip
    If you get stuck, I have all the Cherry Clough articles on a DVD from
    one of their seminars. I can email you the article.
    ---snip
    Aha, Interesting, what was the part no of the PE transfomer you used?
    Barry
  10. Paul Mathews
    Paul Mathews Guest
    P0584:
    http://www.pulseeng.com/products/datasheets/P515.pdf
    Paul Mathews
