Linux and spice
F
framin
Hi to all,
I'm looking for a version of spice which runs under Linux.
I tried to use gEDA with ngspice but it doesn't work.
I've tried to use it a lot of time.
Thanks to all
Franco
Hi to all,
Thanks to all
Franco
Go and ask the gEDA user-group/mailing-list what you are doing wrong.
They are a smart and helpful bunch.
Just searching the mailing list might be enough to crack the problem.
I
Ian Bell
framin said:
Hi to all,
Thanks to all
Franco
LTSpice runs fine under wine.
Ian
Hi to all,
Thanks to all
Franco
Ngspice works fine under Suse 10.
John Devereux
framin said:
Hi to all,
SwitcherCAD (LT Spice) works under Wine. The developer specifically
tests this scenario, I believe.
JeffM
R
Rich Grise
How do you search a mailing list?
Rich
jasen
Hi to all,
ltspice running under wine.
works good.
Bye.
Jasen
jasen
Wine, of course.
Just install wine, on this debian system I did "apt-get install wine" and
it downloaded and installed wine.
download ltspice, the url is http://ltspice.linear.com/software/swcadiii.exe
then do "wine swcadiii.exe" this will install ltspice
then do " wine 'c:\Program Files\LTC\SwCADIII\scad3.exe' " when you want to
run it - it's probably convenient to create a script or launcher that does
that to save typing.
Bye.
Jasen
R
Rich Grise
I downloaded the latest and greatest source, so I have:
$ wine --version
wine: glibc >= 2.3 without NPTL or TLS is not a supported combination.
It will most likely crash. Please upgrade to a glibc with NPTL support.
wine-0.9.34
Hmm - this is the first time I've tried wine --version; I don't understand
that glibc thing: I'm running Slackware 11.0;
$ uname -a Linux heartwood 2.4.33.3 #1 Fri Sep 1 01:48:52 CDT 2006 i686
athlon-4 i386 GNU/Linux
and when I do
$ wine /G/Software/swcadiii.exe
it does this:
wine: Unhandled page fault on write access to 0x003ffd80 at address 0x60cf2103 (thread 0009), starting debugger...
Unhandled exception: page fault on write access to 0x003ffd80 in 32-bit code (0x60cf2103).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:1007 GS:0000
EIP:60cf2103 ESP:0033e718 EBP:0033ea80 EFLAGS:00210212( - 00 - RIA1)
EAX:0033ebb0 EBX:60cf9ff4 ECX:60cf12e0 EDX:00000001
ESI:003ffbe0 EDI:60017020
Stack dump:
0x0033e718: 0033e758 60cf885c 0033e758 0033e754
0x0033e728: 00000000 00000000 0000eb58 00000005
0x0033e738: 00001000 00000001 0000ee5c 60017020
0x0033e748: 60cfa1b4 60cfa1b8 0033e9d8 0000001e
0x0033e758: 46203123 53206972 31207065 3a313020
0x0033e768: 353a3834 44432032 30322054 60003630
0200: sel=1007 base=7ffdc000 limit=00001fff 32-bit rw-
Backtrace:
=>1 0x60cf2103 pthread_initialize+0x293() in libpthread.so.0 (0x0033ea80)
2 0x60cf87d5 __do_global_ctors_aux+0x25() in libpthread.so.0 (0x0033ea90)
3 0x60cedaa2 _init+0x12() in libpthread.so.0 (0x0033ea98)
4 0x6000c3af _dl_init+0x25f() in ld-linux.so.2 (0x0033eae8)
and on and on for about 3 pages.
Now what?
Rich
I
Ian Bell
$ wine --version
support.
wine-0.9.34
No need to compile it. Go to www.linuxpackages.net where you will find a
Slack pack for wine for slackware. This link should get you straight there.
http://www.linuxpackages.net/search_view.php?by=name&name=wine&ver=11.0
Ian
R
Rich Grise
OK, so I've done that, and I get:
wine: Unhandled page fault on write access to 0x003ffd80 at address 0x60cf1103 (thread 0009), starting debugger...
wine: Unhandled page fault on write access to 0x003ffd80 at address 0x60936103 (thread 000b), starting debugger...
err:seh:raise_exception Unhandled exception code c0000005 flags 0 addr 0x6000c04b
$ wine: Unhandled page fault on write access to 0x003ffd80 at address 0x60936103 (thread 000d), starting debugger...
$ wine --version
wine-0.9.33
So do I need a different library or something?
Rich
I
Ian Bell
support.
0x60cf1103 (thread 0009), starting debugger... wine: glibc >= 2.3 without
support.
0x60936103 (thread 000b), starting debugger... wine: glibc >= 2.3 without
support.
0x6000c04b
0x60936103 (thread 000d), starting debugger... err:seh:raise_exception
0x6000c04b
$ wine --version
support.
wine-0.9.33
Rich
Very interesting. I installed switcherCAD using an earlier version of wine
and have only just upgraded to the version I told you about. I don't
normally run it from the command line but I just tried it and I get the
same initial glibc message you did but then it runs OK. Clearly the
installer will not run at all now from your own tests. I need to look into
this further.
Ian
I
Ian Bell
this further.
Ian
Right, checking on linuxpackages.net reveals that this version of wine is
meant for 2.6 kernels and the error occurs if you run with a 2.4 kernel. So
you could upgrade to a 2.6 kernel or roll back wine far enough to be 2.4
kernel compatible. I run 2.4 kernel so I have to make this decision too.Not
sure which way to go yet.
Ian
I
Ian Bell
So you could upgrade to a 2.6 kernel or roll back wine far enough to be
2.4 kernel compatible. I run 2.4 kernel so I have to make this decision
too.Not sure which way to go yet.
Ian
If you want to keep a 2.4 kernel try the 9.2.0 version of wine from
linuxpackages.net. This does work but has a bug with some dialog boxes -
leaves them blank. The workaround is to minimise then maximise them and the
content is restored.
Ian
jasen
$ wine --version
wine-0.9.34
Now what?
looks like a slackware problem. try rebuilding glibc with those options
turned on.
Bye.
Jasen
Similar threads
M
Replies
3
Views
1K
M
M
Replies
Views
1K
Mark Walter
M
L
Replies
Views
1K
Kevin Aylward
K
