Six_Shooter
- Nov 16, 2012
- 98
- Joined
- Nov 16, 2012
- Messages
- 98
Here's the situation:
I have a 2000 GMC Yukon that has factory CD with remote cassette.
Well there is no auxiliary input and want to feed the output from my iPhone or iPod, or hopefully as soon as I get a Samasung phone...
Anyway, what I'd like to do is replace the slave cassette unit with an aux input. The audio signals are easy enough, they are easily connected.
What people have been doing is just leaving the cassette in place and when they want to listen to their aux devices, they just push a cassette into the player to trigger the main uit to switch over, hokey.
On the back of the unit is several connections, one of which is called an E&C pin (Entertainment and Convenience), that sends a certain pattern of pulses to the main unit when the cassette is engaged and then a different pattern when it is ejected.
Here's the issue:
I have a PC based Velleman scope that I can't seem to get to trigger as a single shot, for whatever reason. I do however have a Digiview logic probe. Sounds like a simple fix, right? Just connect the logic probe and capture the output, but not so fast. The output of the E&C pin I have measured at about 14V, the logic probe is only good up to 5V and I have been warned to head that limit very carefully with this particular unit.
So what I have come up with is a simple zener diode circuit, that according to Multisim seems to do exactly what I need it to, at least with a static input voltage of 14V.
The circuit is simply a 4.7K ohm resistor in series with two 1N5222B zener diodes. With these values I should have just under 2mA for IZT, which is much less than the max of 500mA that these diodes are rated for.
Is this a good solution? Will this allow for waveform capture, that happens very quickly without allow any over voltage to the logic probe?
TLDR; Trying to limit voltage input to my logic probe, wondering is a series resistor zener diode circuit is a viable solution?
Here's the issue:
