Limiting\Clamping Circuits
Discussion in 'General Electronics Discussion' started by Gary Dent, Feb 25, 2012.
  1. Gary Dent
    Gary Dent
    6
    Feb 13, 2012
    Zener diodes are often used in clamping circuits as shown http://en.wikipedia.org/wiki/File:Zener_Diode.svg,
    I understand that once the waveform reaches a certain threshold given by the zener diode the zener diode stops conducting, my question is why doesnt the voltage fall to 0 from here? That is on the image I linked to there is a flat line at xV where x is not 0, this implies a DC voltage of some sort.
  2. jackorocko
    jackorocko
    1,284
    Apr 4, 2010
    A zener diode will conduct two ways. Like a normal diode when it is forward biased by about 0.7V and reversed biased (depends on the reverse breakdown voltage). The only time a zener will not conduct is when either the forward or reverse voltage threshold has not been met.
    http://www.allaboutcircuits.com/vol_3/chpt_3/11.html
