Limiting car audio volume
Discussion in 'Audio' started by richard2012, Jan 21, 2014.
  1. richard2012
    richard2012
    Jan 21, 2014
    Despite many entreaties my teenage son still insists of having the audio volume far too high in his car. Could I limit this by wiring resisters in parallel with the speakers without damage to the amp - eg if the speakers are a nominal 8 ohms would it be ok to wire 8 ohms resistors across the speaker terminals?
  2. Externet
    Externet
    733
    154
    Aug 24, 2009
    It would be more like ~20 ohm resistor in series to each speaker. Until he finds out and bypasses them
  3. GonzoEngineer
    GonzoEngineer
    321
    Dec 2, 2011
    I would wire 2 ohms across each speaker, then he will blow the amp and your problem is solved!
  4. BobK
    7,680
    1,685
    Or a 1000V supply to the volume knob.
  5. (*steve*)
    25,361
    2,756
    Or remove the keys from the ignition.
  6. davenn
    davenn Moderator
    13,558
    1,854
    well that's the sledgehammer approach hahaha
  7. flippineck
    flippineck
    269
    9
    Sep 8, 2013
    if the amp is expecting to see 8 ohm speakers and claims an RMS max output of 500 watts
    get 16 ohm speakers capable of handling 250 watts RMS, and wire 16 ohm resistors (or near equivalent) capable of dissipating 250 watts across their terminals
    making, the amp split it's output equally into a noise producer on the one road, and a heater on the other road, I'm thinking mr kirchoff here
    I am not an AC expert though and music is basically AC?
    miladdo will find out and reverse engineer the reverse engineering in no time though lol, aye
  8. jcurrie
    jcurrie
    128
    Feb 22, 2011
    you could remove the knob ,or you could super glue the volume control to a reasonable setting
    jc
  9. davenn
    davenn Moderator
    13,558
    1,854
    sounds like a good plan haha
  10. solo2racr
    solo2racr
    142
    Aug 21, 2013
    On a more serious note, we would really need to know more about the system he has in place. There are a few methods available, depending on what he has.
