T
Tim Williams
Nobody really makes a Magic-Joerg-Block where the output saturation is
adjustable (and preferably, accurate), so naturally, I made my own.
http://www.seventransistorlabs.com/Images/Limiter.png
Threshold between inputs is, of course, exponential (tanh more precisely,
I suppose). The comparator output crosses threshold over 10s of mV
difference, good enough for most purposes. Put an op-amp or comparator in
if you'd like it sharper?
I find 31mV offset with fresh-out-of-the-bag transistors (say, that's
about a V_TH). So unless you get lucky with a monolithic matched set,
you'll need the offset trimmer, or a fancy op-amp setup, to do better.
Tim
Tim
