Hello,
Quick question: is there some way I can limit how much voltage something draws on a power source? For example, can I limit a 24 volt motor to only draw 12 volts from a power source?
The issue I'm having is a motor that takes 12-24 volts tries to suck 24 volts out of a 12-volt power supply. The power supply is reporting "power trouble" as the motor is trying to get 24 volts- something the power supply can't provide. The "fuseless protection monitoring algorithm" then cuts off power. So... what can I do about this?
Thank you all so much for any help you can give me!
If I posted this in the wrong forum section or something, I apologize in advance!
Sam
Sam
