Ed said:
I am trying to design a warning sign with several bulbs which a section of
the bulbs turn on while the other section just stay off. Then the section
that just turned on would turn off and the other section will turn on. Can
anyone give some help what to do to get that project finished. Thanks in
advance.
Ed
Hi, Ed. If you're using a DPDT relay and you've got a 12VDC supply
available (you can always use a wall wart), this may be the easiest way
to do this (view in fixed font or M$ Notepad):
| CRY1B
| o---o NO
| .--o--__
| | o---o NC
|VCC VCC '----------o C
| | NC |
| '---o ___ |/ NPN Darlington
| __--o-|___|--o---|
| .---o C R | |>
| | NO +| |
| | C --- |
| | --- C|
| | | C|RY1
| | | C|
|GND GND GND
(created by AACircuit v1.28.6 beta 04/19/05
www.tech-chat.de)
Look for a 12VDC relay with a 400mW coil. You can use just about any
NPN darlington in a TO-220 package. With a 1000uF cap and a 1K
resistor for R, you should have a total cycle time of around a second.
The idea behind this circuit starts with the fact that a 12V relay will
typically turn on at about 9V or so. Once it's on, the voltage across
the coil typically has to drop to about 4V for the relay to open up.
When power is applied, the cap is at 0V, so the relay will be off. The
normally closed (NC) contact starts charging cap C up to about 10.4V,
which will put about 9V at the coil, turning the relay on. The contact
changes over, and the resistor R is then connected to GND, discharging
the resistor until the cap voltage gets down to about 5.4V, which means
there's less than 4V across the coil. This makes the relay turn off,
which repeats the process.
Hook up your lights to the N.O. and N.C. contacts of the other pole of
the relay.
There are a couple of limitations to this circuit. First, the duty
cycle (% time on) is pretty much fixed at a little less than 50% (it
takes a little longer to charge up than discharge, because the base of
the darlington is stealing a little current from the cap). You can
provide some control over total cycle time over a limited range by
putting a pot (say, 2K to 5K) in series with the R. This will give you
up to several seconds cycle time. Timing on this circuit is
susceptible to change with mechanical vibration. Also, this circuit
won't work very well at lower voltages (although it will work well at
24VDC).
If this doesn't do it, possibly you could provide a little more
information (like what voltages you have to work with, what kind of
timing cycle you want, and what kind of precision you need in your
cycle time).
Good luck
Chris
