M
Michael Kennedy
I have a ethernet cable that runs from my house to an out building at my
house. I live in Florida and we have a real problem with lightning around
here. I plan on using a a TII telephone lightning arrestor on each end.. I'm
talking about the kind that the telephone company puts on the side of your
houese with the gas arrestors inside.
I think this will work but I have one problem.. I don't know if a ground
rod at the out building will be enough to ground a lightning strike. The
building doesn't have a ground rod right now but I was planning on putting
one in for this..
How do you get a good ground with a ground rod. I have tried driving one
down but when I ohm it there is always a lot of resistance vs the power
company's neutral / ground. I was told that a good ground rod will have
about 15 ohms of resistance between the rod and the system ground.
I would just hook this arrestor up to the out building's ground wire, but
the ground and the neutral are tied togeather and I don't think there is a
very good ground out there because the ground on the CATV wire will shock
you if you touch it and a ground in the building out there. On the voltmeter
it reads about 3v between the catv wire ground and the bldg ground.. So I
think my ground is overloaded or has a bad connection at the breaker
pannel.. It has 2 legs of 120v and one neutral. There is no seperate ground
wire.
Thanks for any advice / help..
- Mike
one in for this..
wire.
- Mike
