C
Clive Mitchell
I suppose this is a sort of public disclosure of prior art thing...
26th October 2004
What do you guys think of this idea?
A solid state wash luminaire with a beam that can be positioned, changed
in angle and colour with no moving parts. It would consist of a sphere
or part thereof that was covered in small high intensity directional
light sources which could be LEDs or another technology. The projected
light intensity, colour and pattern could be controlled by selectively
lighting up sections of the light sources on the surface of the unit.
The output beam shape and width would be controlled by illuminating the
light sources in patterns. For instance, a small circle of emitters lit
on the surface would project a narrow circular patch of light. A wider
circle would give the effect of a wider beam angle, while a strip of
illuminated emitters would give a cyclorama style wash.
Colour would be controlled if desired by using clusters of red, green
and blue light sources.
Changing the position of the projected beam would be achieved by
changing the area of illuminated emitters on the surface of the unit.
In most instances a typical limited angle stage light could be
implemented by a quarter sphere of emitters or less. A typical club
version would have anything from half a sphere up to nearly a full
sphere (allowing for cables and anchorage).
A light like this could be achieved using current technology high output
LEDs for low lighting level environments, but the idea will be much more
versatile as miniature light emitters like LEDs evolve. Video wall
technology would lend itself well to the control of the light sources.
Just thought I'd mention this concept to keep it in the public domain
and prevent it being patented. (Assuming no one else has patented the
concept in this form already)
Spherical video walls have been built before (EPCOT comes to mind) but
I'm not aware of any device that performs the function described above.
If it's original then print out a copy of this post for future reference
and prior art use. (Guess which company inspired this behaviour!)
26th October 2004
