Y
Yvan
I want to make light dimmer for my car to use as daytime running lights
(now required here by law), and I found this:
http://www.electronics-tutorials.com/devices/555-light-dimmer.htm
What do you think about this design?
Each headlight bulb is fused separately, and both are grounded at the
headlight housing. So I need to do some modifications to the circuit.
Can I just add another power mosfet, and connect it to the pin 3 of 555
(to the same pin as existing one)?
And, since both H1 headlight bulbs are grounded I have can I just
connect +12V to the pin 2 at the mosfet, and put the bulb between the
pin 3 and ground? Or do I have to use different mosfet?
BTW I couldn't find MTP3055E locally, so I bought BUZ60.
As you can see I am electronics newbie, so go easy on me
