B
Bart Z. Lederman
I realize this can be a somewhat "hot" topic, but I'll ask
the question anyway.
Honeywell has come out with an easy to install (one hole)
Ultraviolet light that can be added to forced air vents. The
cost seems reasonable, so I decided to add one to my home
heating / cooling system. It uses a CFL without the "F": a
lamp about 6 inches long, two parallel tubes, for pin in-line
base, but clear (no phosphor). It also comes with a lot of
warnings not to look directly at the lamp, and has warning
stickers to put on the HVAC equipment. There is a plastic
indicator that glows to show the lamp is on.
There is no switch on the device: the lamp is on all of the
time. My thinking is that it's not going to be doing much good
while the air isn't circulating past it. (The instructions
point out you can position the lamp so it will irradiate the
air-conditioning coil, if you have one, which would be good for
keeping mold from growing on any condensed moisture. But the
way my unit is set up there isn't a good place to put the lamp
to do that.) So I'm thinking of hooking it up to a circuit
where it will get power only while the circulating fan is
operating.
This, of course, leads to the hot topic: can I expect
better lamp life if the lamp is on all of the time, or will it
be better if the lamp isn't operating while the fan is off, but
will have to start more often.
I realize the answer is going to depend a lot on the duty
cycle of the fan, and I can probably take some measurements in
the future to find out what that is: but if anyone has any
experience in this area and would like to express an opinion,
I'm interested.
(I've taken lighting design courses, but this topic wasn't
covered: and CFLs were developed long after I took the course.)
Thanks.
operating.
I'm interested.
Thanks.
