Li-ion Batteries.
Discussion in 'Power Electronics' started by ngunter, Dec 23, 2012.
  1. ngunter
    ngunter
    Dec 23, 2012
    I was looking to upgrade a laptop battery I have, which doesn't hold much charge. I am looking to change the individual batteries within. I just have 1 question.
    The total rating for the battery pack (x6 batteries) is: +11.1V, 4400mAh, 46Wh.
    Does this mean each battery is 1/6 of the total rating. e.g 1 battery = 1.85V, 733.3mAh, 7.6Wh?
    Thanks.
  2. (*steve*)
    25,505
    2,852
    The Wh rating will be close, but the batteries will be Lithium cells with a terminal voltage between 3 and 4 volts.
    Most likely these batteries are connected as 3 sets of pairs of batteries. Each pair is in parallel and these are placed in series (alternatively there are 2 sets of three cells in series that are placed in parallel.)
    The battery will fall to a little under 9V when flat, and rise to a little over 12V when fully charged.
