John Wayne
Let me start out by saying I am not an electronics tech but do understand
basic electronics and schematics and have read the s.e.r. microwave faq and
understand the precautions about working on high voltage equipment and
discharging same.
Anyway my problem is my LG over the range microhood.
Got is from a liquidator about a year ago so is not under warranty and from
the near thestart there was the occasional arcing sound which recently got
quite frequent and now it does not heat at all.(or arc).
I pulled the covers and made sure the capacitor was discharged and took a
few measurments and the leads to the magnetron read about 0.8 ohms which
seems ok according to the faq but the diode from the capacitor to ground
reads open both directions so I suspect that is the culprit.
The problem is the intermittent arcing from the start which if I replace the
diode will most likely return and in fact the wave tunnel where the
magnatron is attache to has the paint scorched off of it for about 2" area
above where the magnetron attaches below.
I believe it said something in the faq about touching up the paint for
arcing problems but did not say what kind of paint to use.
So my questions are should I get a replacement diode and remove the
magnetron and clean up the wave tunnel and repaint it and if so with what
kind of paint or does this indicate a problem with the magnetron as well?
If not is it worth putting it back together and taking it in for repair? A
new one like this will run about $275 buck here.
discharging same.
