LG Microwave Oven
Discussion in 'Electronic Repair' started by Jerry Fixall, Dec 30, 2006.
  1. Jerry Fixall
    Jerry Fixall Guest
    This microwave stopped heating. I tested the elctrical circuits an
    discovered a bad diode that was connected to the capacitor. I called L
    due to no part#'s. in the manuals. I called and spoke to the parts dept
    , they told me that they can not identify the part due to too man
    diodes in the system.The diode has the following info on it HVR-1X , S
    3018. Does anyone know where I might be able to purchase this diode
  2. What is the voltage rating of the main capacitor (the one which will kill
    you)?
  3. Jim Land
    Jim Land Guest
    has the following info on it HVR-1X , SK 3018. Does anyone know where I
    might be able to purchase this diode ?
    The HVR-1X is a common diode for microwave ovens. It can be replace with
    an NTE517:
    http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/69d5aa3584d015ce85256e78005
    6e56f?CreateDocument
  4. jomiservice
    jomiservice Guest
    Be carefull in testing the diode with a normal ohmeter. It seems to b
    open in both directions.
    because of the high impedance.
    Perhaps your problem is the magnetron
    Jom
  5. Franc Zabkar
    Franc Zabkar Guest
    Mouser has an equivalent:
    http://www.mouser.com/search/ProductDetail.aspx?R=NTE517virtualkey52600000virtualkey526-NTE517
    http://www.nteinc.com/specs/500to599/pdf/nte517.pdf (datasheet)
    - Franc Zabkar
