H
[email protected]
Hi All,
I need to produce 4 PWM signals to input to 4 power MOSFETs that are
driving 4 DC motors. The MOSFET side of things is done/tested/working.
Currently I'm producing the PWM signals with a computer I/O interface,
however since I'm going with an embedded solution I want to give the
PWM generation to the hardware to take some burden off of the embedded
controller as it has other things to do.
I've looked at ICs like the Tl494 or the UC1824 for PWM generation,
but I'm not sure they are the best for motor control, and I've had a
really hard time finding some simple application notes on these 2 ICs.
Basically, I'm looking for a single IC solution that will allow me to
give 4 analog signals to the chip and will produce 4 unique PWM
signals with minimal external components. The PWM frequency is
flexible.
If a 4 channel Voltage-to-PWM IC is not available can anyone suggest
the simplest single channel Voltage-to-PWM IC that will require
minimal components for my application?
If anyone has any suggestions, please let me know.
wind-it-up
flexible.
wind-it-up
