LF: Schematic for HP inkjet printer cartridges
Discussion in 'Electronic Repair' started by Kirk, Apr 15, 2004.
  1. Kirk
    Kirk Guest
    Yes that's right, HP inkjet printer cartridges. Need to know what the
    circuits are on the cartridge from the contacts to the print head. Tried to
    meter this out and it's not making much sense of the readings using an ohm
    meter.
    Email me if you need more info. remove the _nospam_
    670-2195
    Shop Hours
    Monday to Friday 10 AM to 10 PM
    Saturday 10 AM to 8 PM
    Sunday, Call
    875 Hamilton Road, London, ON, CA,
    (Hamilton and East Street, near Highbury)
    Back door of LCW Online (The Box Gamez Room), Parking at rear of
    building, Please come in. Shop is down stairs through the gate.
  2. Kirk
    Kirk Guest
    Need just about any known cartridge that is still in use. Any one or all of
    these if anyone can. HP will not give out this information because they don
    not want anyone remanufacturing used cartridges.
    C1823
    C6578
    C6614
    C6615
    C6625
    51625
    51626
    51629
    51633
    51645
    51649
    C6656
    C6657
    C6658
  3. Beau Schwabe
    Beau Schwabe Guest
    Are you kidding me?
    There is a propietary IC that for the most part consists of several
    OP-Amps designed to drive inductive loads. I know this because I
    did a metal spin in silicon for a redesign to slightly improve the
    performance of a particular cartridge, but beyond that I don't think
    your going to have much luck. If you just want a pin definition of
    what is on the cartridge itself, then there should be a speck sheet
    out there somewhere. If HP is not willing to work with you then
    perhaps you can find a third party that has a printer that can use an
    HP cartridge. You may have to reverse engineer it from the printer
    end rather than from the cartridge, but be warned that there is
    probably a good reason why HP is not disclosing information to you.
