LF 12 volt LCD monitor 15 to 17 inch
Discussion in 'Boat Electronics' started by PR, May 11, 2007.
  1. PR
    PR Guest
    Would anyone happen to know of a supplier of 12 volt LCD's hopefully in
    Canada? Don't need marine spec as such just 12 volt.
    Thanks...
  2. Hanz
    Hanz Guest
    I would go to a computer/best buy and look at the monitor. The 12v ones
    have an external 'brick'. If it has output of 12v and the monitor looks
    'good' buy it.
    BUT. I won't run it off the house battery. They have voltage anywhere
    from 10v to 14.5v. I've been running monitor/tv and computer off my
    house battery BUT I have a 12v-12v converter. Look at
    :http://www.logicsupply.com/product_info.php/cPath/40_63/products_id/504
    It can run from 6v to 24v. I put them into a box and run a line with the
    plug into the monitor/tv.
    The tv I got from Walmart and the monitors I got from BestBuy.
    Hope this helps.
    Hanz
  3. PR
    PR Guest
    Thank you for that advice Hanz - it seems to be a good idea. I'm actually
    sourcing for a marine customer so I'll offer them that solution. Boats
    definitely would have an unstable DC supply.
    Russ
  4. Hanz
    Hanz Guest
    Be carefull of RFI from AC-DC inverter.
    Hanz
  5. Al Thomason
    Al Thomason Guest
    Surplus HP F1064A DC-DC converts. They were designed for their 12v
    Lap Tops to run off of car "12v" so have a wide range of input
    voltages supported. They supply I think around 50 watts.
    Shows up on Ebay every once and a while for under $10
    -al-
  6. I use a small DC stabiliser from a UK company called Amperor. It works very
    well indeed.
    http://www.amperordirect.co.uk/products/12v_Stabiliser.asp
    Stewart
