S
Stefan Oedenkoven
Hi ng,
i'm currently building a serial controller between a 5V and a 3.3V
microcontroller. Maybe someone of you can tell me, if there exists any
common electronic component which can convert digital signals at ~ 1MHz with
high level varying from 3.0 to 5.0 Volt and should output a signal with high
level at 3.3Volt . (low level is always 0V)
first i tried to build a simple voltage divider with two resistors, which
was only acceptable with stable 0V Low /5V High input... the other problem
is a fixed input capacitor at the 3.3V device of 50pF which - in combination
with my voltage divider - passed only low frequencies.
thanks in advance,
Stefan
thanks in advance,
Stefan
