Hi folks, I have a project I want to get started on that involves 4 dc motors 1.5-3v 270ma and one laser diode which I am assuming is 3v since it runs on 2 AAA batteries I have no idea on amperage as I have no details in that regard. If you haven't guessed it already, I'm trying to build a laser Spirograph.
So what's the big deal right? I want the motors to be variable of course, AND reversible. The device will be manual control only. As in no need for micro controllers or any other fancy doodads.
I know how to wire up a reversible system with DPDT switches, and would like to stick to that. And that's just about the only thing I know. So my question(s) to you guys;
Power supply: since I have 5 loads of 3v max each, how do I determine the voltage on the needed DC power supply? does this mean I need something in the 15v range, or will some kind of 3v power supply work? Do these different loads need to be wired up in series or parallel?
Potentiometers: since the motor speeds will be variable independent of each other, how do I calculate out what pots I'll need once I get the power issue figured out?
I'm actually trying to learn a few things here so I kind of don't just want parts numbers, more at what way(s) I can figure some of this stuff out.
