Perhaps I'm a little too young and the equipment I'm thinking of came
along later than the stuff at that link, but most all of it appears to
have incandescent lamps. Nothing that can me frapper avec ces rayons
laser.
It did tend to be mostly incandescent. The only deviation from that was
the odd fixture that used lamps like HMI 575's which were mind numbingly
expensive then.
In those days they used absolutely every type of powerful lamp they
could find. A popular choice for flat beam effects in some flying
saucers and "Derby" effects was the humble linear 500W floodlight lamp.
Instead of being operated horizontally as usually specified for this
lamp, it was spun around to the beat in front of a bank or dome of
coloured lenses to create multiple synchronised flat beams of coloured
light. (Actually the projected image of the filament). Despite all
this spinning the lamps lasted for ages and only cost a couple of
dollars to replace. Not bad given the normal cost of projection lamps.
Even given the relatively wasteful nature of the humble moonflower
effect where a parabolic dish of mirrors reflects a series of images of
a halogen filament lamp out of a lens, the visual effect from even a
modestly powered lamp is very good.
I used to service SGM plus lights for a friend. These were a mutha of a
moonflower with an HMI 575 inside and large dichroic semaphores raised
and lowered by motors. It also had a three axis mirror on the front and
was so sharp and powerful that many thought it was a laser.
I wonder who invented the moonflower.
