There are a lot of different kinds of LED on the market these days. I'm
trying to understand some of the distinctions.
I'm seeing some called "low-current" (e.g., Fairchild HLMP-D150). They
don't seem to be any different than normal LEDs, except they're
characterized at low currents. But after all, any LED works at low
current - they're generally pretty linear over several decades, far as I
can tell from the datasheets.
So, what makes something be a "low-current" LED?
Some LEDs have high efficiency at low currents, and a few have high
efficiency only at low currents. Some high brightness and high
efficiency LEDs have high efficiency only at higher currents.
Examples of low current LEDs:
1. Red GaP (GaP is normally green), AKA GaP doped with ZnO, or red with
peak wavelength (do not confuse with dominant wavelength, a color
specification that roughly but not quite exactly means hue) of 690-700 nm.
These have been in use as far back as the mid 1970's. Efficiency
maximizes at 1 mA or less. The color turns orangish, sometimes even
yellow-orange at higher currents like 30 mA, which is normally safe for
these.
2. Original silicon carbide (without gallium nitride) blue. These appear
to me no longer in production. Efficiency of these is low, but not as bad
at lower currents. Efficiency appears to me maximized at somewhere
near or less than .5 milliamp.
3. InGaN blue, green, and white. Efficiency of "regular size" ones is
usually maximized at a few mA. Cree makes a series of smaller size chips
of InGaN chemistry that they call "low current", and have efficiency
probably maximized at 2 mA or a little less. Note that InGaN has
impressive efficiency and high brightness at "full current", even though
the efficiency is even higher at a few milliamps.
There is an older "high efficiency red" chemistry (orange-red GaAsP
on GaP substrate, related to yellow) that started seeing widespread use
sometime around 1980. Then there was GaAlAsP (starting in the mid
1980's), the first Superbright"/"Ultrabright" red. It was improved
afterwards by making the substrate transparent (GaP instead of GaAs).
Then there was InGaAsP, available in colors from slightly orangish red to
yellow-green and the ultimate chemistry of current LED technology for
these colors.
All of these along with red GaAsP (on GaAs substrate), yellow GaAsP on
GaP substrate and green GaP had lower efficiency at low currents. The
variation of efficiency with current led many people to believe that there
was a trick in human vision to take advantage of by pulsing such LEDs.
But no, human vision is surprisingly linear prior to a time-integration
process - the nonlinearity was in the LEDs.
I do suspect that a few "low current" LEDs do not have efficiency
maximized at low currents but are merely characterized for performance at
low currents. They may lose efficiency from low current less than others
of similar chemistryu. I have heard of some "low current" GaP green ones.
- Don Klipstein (
[email protected],
http://www.misty.com/~don/ledx.html)
