nicksticks
- Apr 14, 2012
- 4
- Joined
- Apr 14, 2012
- Messages
- 4
Hi I am trying to build an aquarium light using 30 star LEDs (its going to be very bright!). I've had some trouble with 12V power supplies that I bought on ebay (big surprise) and I have had the idea of simply cutting the 240V supply in half to 120V with a diode, smoothing it with a capacitor and running the LEDs connected in series from that. I have attached a diagram of the circuit.
The LEDs are 3W each and are rated to use 3-4 V but they can tolerate 6V for at least 30 seconds. If they use 3W at 3V thats 1 amp. Their resistance is therefore 3 ohms minimum. 30 in a row is 90 ohms. Connected to 120V that is 1.3 A, a bit much but close enough at least for a test run. If it works I will buy a dimmer to control the voltage (I can get one on ebay )
One of the problems that I can see is the fact that the capacitor will initially draw a very large current as it charges. It is an electrolytic capacitor and so should have a reasonably high internal resistance which might make it ok. I am also not sure that the capacitor will sufficiently flatten the voltage peaks and maybe the voltage peaks will kill the LEDs.
Can I please have some opinions and advice for my circuit?
