falcon3497
- Aug 11, 2021
- 1
- Joined
- Aug 11, 2021
- Messages
- 1
Hello all,
So I'm playing around with LEDs for the first time. I'm trying to power 3 LED diodes using a 12v 5A DC plug. I did some research online and calculated the forward voltage of each diode (two of them are 2 volts and one is 3.4 volts) and determined the resistors needed for each diode if I'm supplying 12v (the 2 volt diodes each have a 510 ohm resistors and the 3.4 volt has a 470 ohm resistor). I soldered them to a female 12V receiver, and they light up. Success so far.
My concern is, is that the resistors seem to be getting unreasonably hot. Each diode is supposed to run at 20 milliamps, and so given that the 12V power source is 5 Amps, I fear that may be the issue. Is the power source the issue here, or did I do my math wrong? If so, how can I rectify this? I'm doing a parallel circuit by the way.
