LED
Discussion in 'Electronic Design' started by Jennie, Oct 5, 2004.
  1. Jennie
    Jennie Guest
    I have a FR200 radio with a light bulb attached. I am looking to hook up a
    LED that is the best energy miser.
    I am using a 5mm LED that is rated 20mA and 3.6 Volts - radio shack
    FR200 = 4.5 Volts 3 AA Batteries at 1.5 each...Volts is series Volts
    increase and Amps stays the same.
    R = (Vs - Vr) / I
    R = (4.5 - 3.6) / .020 = 45 ohms
    What is the most energy miser bright LED out there? One to give me lots of
    light time?
  2. Jennie
    Jennie Guest
    Is this the right newsgroup to ask this type of ?
  3. Jennie
    Jennie Guest
    Where are the high efficiency leds?
  4. You can operate any LED at a current well below its specified maximum,
    with an almost proportional decrease in light output. Experiment with
    the ones you have with current at .01 and .005 amp and see if the
    light is bright enough. The only way yo make the battery last longer
    is to find one that has high efficiency, so you can run at the lowest
    possible current.
  5. sci.electronics.basics would be better.
  6. Rich Webb
    Rich Webb Guest
    Google knows...
  7. LEDs are sold many places. Where did you get the last one? The key
    specification is the luminous intensity (usually specified in mcd or
    millicandelas). Divide that number by the specified current and you
    get millicandelas per milliamp. This is the conversion from current
    to light efficiency.
    For example, these LEDs sold through Digikey have the following specs:
    http://rocky.digikey.com/WebLib/Fairchild/Web Data/MV8W00.pdf
    typical 2500 mcd at 20 ma, 125 mcd/ma.
    http://rocky.digikey.com/WebLib/Lumex/Web Data/SSL-LX5093XUWC-TR.pdf
    typical 2300 mcd at 20 ma, 115 mcd/ma.
    Whatever kind you get, run it at the lowest current that gives enough
    light.
  8. Jennie
    Jennie Guest
    Radio Shack...
    MCD 1100 at 20mA, 55mcd/ma Is the lower the number, mcd/ma, a more
    efficient LED?
  9. No. Millicandela is about 1/1000 of the light of a candle. More MCD
    is more light (what you want) for the same current (what you have to
    pay). The same way higher miles (what you want) per gallon (what you
    have to pay) is a more efficient automobile.
  10. Jennie
    Jennie Guest
    Thanks, where is a good explanation of how a led works, etc....
  11. HP's 2nd edition of "Optoelectronics/Fiber Optics Applications Manual." (If you
    can find them after I sucked up a dozen of them from various sellers on the web
    last year and sent them to people I knew would be interested.)
    Jon
  12. Clarence
    Clarence Guest
    Here is somethings to start with
    http://csm.jmu.edu/physics/hughes/APL_66_115.pdf
    OR
    http://www.engineering.vcu.edu/fac/morkoc/learning/science.pdf
    AND
    http://www.lumileds.com/pdfs/protected/AB12.PDF
    OR if you really need it and will pay for it.
    http://ao.osa.org/abstract.cfm?id=25107
  13. Clarence
    Clarence Guest
  14. Rich Grise
    Rich Grise Guest
    Some time ago, there was a thread about letting a big cap discharge
    through a LED, and "does it dim continuously, or wink out at the end",
    so I did the experiment. From 20 mA down to 10 I didn't see any
    noticeable change in brightness (probably would have if I'd had 2),
    and it gave light "smoothly", all the way down to 0.
    So do some experiments. I wouldn't be surprised if there's a LED
    that would give you a usable indicator at just a couple of mA.
    Good Luck!
    Rich
  15. My super-greens are usefully bright (under room lighting, narrow
    angle) at just 250uA.
    Best regards,
    Spehro Pefhany
  16. Jennie
    Jennie Guest
    Some LED's glass is so distorted the light has to be distorted too..
  17. Jennie
    Jennie Guest
    Where do u get the LED's?
Similar Threads
  1. led
  2. LED
  3. LED
  4. LED
  5. LED
  6. led
  7. Led
  8. LED
Loading...
