led
Discussion in 'Hobby Electronics' started by Zman, Dec 21, 2004.
  1. Zman
    Zman Guest
    Hey there
    when placed in the sun, a small led gives off a reading on my voltmeter,
    goes up and down. The only thing is, how do i know what reverse
    current/voltage im going to get just by looking at the information? is there
    a formula to use and does mCd make a diff in voltage or current when giving
    power out?
    the specs are
    15VDC 5mm LED
    (all typical values)
    luminous intensity 120
    Peak emission wavelength 573
    spectral half width 15
    flash rate (freq) 2.4
    operating voltage 5
    forward voltage 5
    reverse voltage .04
    thank you
  2. Eddie
    Eddie Guest
    strange led spec, but yes, not many people know that a led will generate a
    small voltage and bugger-all current when exposed to light
  3. Didn't you like the fairly comprehensive replies before ??
    Why use a flashing LED for this purpose ??
    Particularly against expert advice ??
  4. MC
    MC Guest
    Actually *all* semiconductors will produce some voltage and current
    if given enough radiation.
    One reason why most semiconductors are enclosed in optically-opaque
    packaging is to try and reduce optical side-effects.
    Unless the device has been specifically designed for power generation
    (ie. a solar cell), then you'll find that the enery-conversion
    efficiency is rather low and the output will depend a lot on what the
    semiconductor material actually is.
Similar Threads
  1. LED
  2. LED
  3. LED
  4. LED
  5. led
  6. Led
  7. LED
  8. LED
Loading...
