LED UV emissions?
Discussion in 'Hobby Electronics' started by Wayne., Mar 5, 2009.
  1. Wayne.
    Wayne. Guest
    Just curious, but does an off the shelf white or blue LED emit any UV of
    a usable level?
    I use a CFL for UV exposure, but it is a PITA to set up, and for the
    cost of one UV LED, I can by a bag of 10 ultra white or ultra blue LEDs.
  2. **Even better, you can buy UV LEDs. They're not really UV, they're deep
    purple, but they do the job. I've used them in place of unobtainable cold
    cathode UV tubes.
    Jaycar ZD-0260
    Farnell 105-7106
  3. Clint Sharp
    Clint Sharp Guest
    Just be careful not to overdrive them or you might get smoke on the
    water.
  4. Wayne.
    Wayne. Guest
    For the cost of one from Farnell, I can buy 10 blue/white LEDs.
  5. K Ludger
    K Ludger Guest
    Very sharp! :)
  6. ian field
    ian field Guest
    The "stupid with a flare gun" inspired the only good single they ever did!
  7. **You asked about UV, not white or blue. If you want UV, use a UV LED.
  8. ian field
    ian field Guest
    You obviously didn't read what the OP said!
  9. **I did. He clearly failed to read what I wrote. You want UV, use a UV LED.
    I don't know how much UV is delivered by a blue or a white LED. I do, OTOH,
    know that a UV LED delivers UV. A UV LED may deliver 10 (or 100) times the
    amount of UV that a white or blue LED delivers.
    It seems simple enough. He wants UV light, he uses UV LEDs.
  10. Bob Parker
    Bob Parker Guest
  11. Bob Parker
    Bob Parker Guest
    I've bought quite a lot of stuff from Lance there. Excellent LEDs
    and other things at good prices, in my experience. :)
  12. Jasen Betts
    Jasen Betts Guest
    I seriously doubt that any blue/white ones emit more than a 2% UV.
    but check for yourself farnell have links to data-sheets (and
    most of them work)
    wikipedia says UV is wavelengths smaller than 400nm, and a quick
    search of a different site found no datasheets for visible light leds
    that emit a measurable amount of UV
    AIUI UV LEDs are made out of a different semiconductor to those used
    for visible LEDs.
