LED Tachometer on atmega8
Discussion in 'Microcontrollers, Programming and IoT' started by Nezvers, Apr 1, 2015.
  1. Nezvers
    Nezvers
    Apr 1, 2015
    hello, i already have working project, but problem is led light interval... its300 rpm, but i need 200rpm. anyone can help? Ready project i will mount in speedometer. i have only instaled program on controlier, but cant modify that how i know. 20150124_173201.jpg 20150124_173456.jpg
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    Hello
    please give us more details. Did you write the software yourself? Do you have a circuit digram. Post your code and explain how it should work.
    Adam
  3. Nezvers
    Nezvers
    Apr 1, 2015
    http://forum.cxem.net/index.php?showtopic=117851&st=40
    here in midle page is circuit, and software found here..there isnt right one for me....here is asambler code but i dont know how to use it, maybe anyone can make hex file from it? :)
    ; BASIC .ASM template file for AVR
    .include "C:\VMLAB\include\m8def.inc"
    ; Define here the variables
    .def temp =r16
    ; Define here Reset and interrupt vectors, if any
    reset:
    rjmp start
    reti ; Addr $01
    reti ; Addr $02
    reti ; Addr $03
    reti ; Addr $04
    rjmp t1cpt ;reti ; Addr $05
    reti ; Addr $06 Use 'rjmp myVector'
    reti ; Addr $07 to define a interrupt vector
    reti ; Addr $08
    reti ; Addr $09
    reti ; Addr $0A
    reti ; Addr $0B This is just an example
    reti ; Addr $0C Not all MCUs have the same
    reti ; Addr $0D number of interrupt vectors
    reti ; Addr $0E
    reti ; Addr $0F
    reti ; Addr $10
    reti
    reti
    t1cpt:
    in r20,TCNT1L
    in r21,TCNT1H
    clr temp
    out TCNT1H,temp
    out TCNT1L,temp
    ; cpi r17,1
    ; breq set_res
    sbr r17,1
    ; rjmp quit_t1cpt
    ;set_res:
    ; clr r17
    ;; rjmp quit_t1cpt
    quit_t1cpt:
    reti
    ; Program starts here after Reset
    start:
    ldi temp,low(RAMEND)
    out SPL,temp
    ldi temp,high(RAMEND)
    out SPH,temp
    clr temp
    out PORTB,temp
    out PORTC,temp
    out PORTD,temp
    ldi temp,0b11111111
    out DDRD,temp
    out DDRC,temp
    ldi temp,0b11111110
    out DDRB,temp
    clr r20
    clr r21
    clr r17
    rcall pusk
    clr temp
    out TIFR,temp
    out TCNT1H,temp
    out TCNT1L,temp
    ldi temp,0b00100000
    out TIMSK,temp
    ldi temp,0b11000010
    out TCCR1B,temp
    sei
    main:
    cpi r17,1
    brne main
    rcall test_out
    rjmp main
    test_out:
    clr temp
    out PORTD,temp
    out PORTB,temp
    out PORTC,temp
    ldi r24, $98
    ldi r25, $3A
    rcall sub_DD
    brcs loc_4C
    sbi PORTB,1
    loc_4C: ; CODE XREF: sub_47+3 j
    ldi r24, $4C
    ldi r25, $1D
    rcall sub_DD
    brcs loc_51
    sbi PORTD,7
    loc_51: ; CODE XREF: sub_47+8 j
    ldi r24, $88
    ldi r25, $13
    rcall sub_DD
    brcs loc_56
    sbi PORTD,6
    loc_56: ; CODE XREF: sub_47+D j
    ldi r24, $A6
    ldi r25, $0E
    rcall sub_DD
    brcs loc_5B
    sbi PORTD,5
    loc_5B: ; CODE XREF: sub_47+12 j
    ldi r24, $B8
    ldi r25, $0B
    rcall sub_DD
    brcs loc_60
    sbi PORTB,7
    loc_60: ; CODE XREF: sub_47+17 j
    ldi r24, $C4
    ldi r25, $09
    rcall sub_DD
    brcs loc_65
    sbi PORTB,6
    loc_65: ; CODE XREF: sub_47+1C j
    ldi r24, $5E
    ldi r25, $08
    rcall sub_DD
    brcs loc_6A
    sbi PORTD,4
    loc_6A: ; CODE XREF: sub_47+21 j
    ldi r24, $53
    ldi r25, $07
    rcall sub_DD
    brcs loc_6F
    sbi PORTD,3
    loc_6F: ; CODE XREF: sub_47+26 j
    ldi r24, $82
    ldi r25, $06
    rcall sub_DD
    brcs loc_74
    sbi PORTD,2
    loc_74: ; CODE XREF: sub_47+2B j
    ldi r24, $DC
    ldi r25, $05
    rcall sub_DD
    brcs loc_79
    sbi PORTD,1
    loc_79: ; CODE XREF: sub_47+30 j
    ldi r24, $53
    ldi r25, $05
    rcall sub_DD
    brcs loc_7E
    sbi PORTD,0
    loc_7E: ; CODE XREF: sub_47+35 j
    ldi r24, $E2
    ldi r25, $04
    rcall sub_DD
    brcs loc_83
    sbi PORTC,5
    loc_83: ; CODE XREF: sub_47+3A j
    ldi r24, $81
    ldi r25, $04
    rcall sub_DD
    brcs loc_88
    sbi PORTC,4
    loc_88: ; CODE XREF: sub_47+3F j
    ldi r24, $2F
    ldi r25, $04
    rcall sub_DD
    brcs loc_8D
    sbi PORTC,3
    loc_8D: ; CODE XREF: sub_47+44 j
    ldi r24, $E8
    ldi r25, $03
    rcall sub_DD
    brcs loc_92
    sbi PORTC,2
    loc_92: ; CODE XREF: sub_47+49 j
    ldi r24, $A9
    ldi r25, $03
    rcall sub_DD
    brcs loc_97
    sbi PORTC,1
    loc_97: ; CODE XREF: sub_47+4E j
    ldi r24, $72
    ldi r25, $03
    rcall sub_DD
    brcs loc_9C
    sbi PORTC,0
    loc_9C: ; CODE XREF: sub_47+53 j
    ldi r24, $41
    ldi r25, $03
    rcall sub_DD
    brcs loc_A1
    sbi PORTB,5
    loc_A1: ; CODE XREF: sub_47+58 j
    ldi r24, $15
    ldi r25, $03
    rcall sub_DD
    brcs loc_A6
    sbi PORTB,4
    loc_A6: ; CODE XREF: sub_47+5D j
    ldi r24, $EE
    ldi r25, $02
    rcall sub_DD
    brcs loc_AB
    sbi PORTB,3
    loc_AB: ; CODE XREF: sub_47+62 j
    ldi r24, $CA
    ldi r25, $02
    rcall sub_DD
    brcs locret_B0
    sbi PORTB,2
    locret_B0: ; CODE XREF: sub_47+67 j
    clr r17
    ret
    sub_DD: ; CODE XREF: sub_47+2 p sub_47+7 p ...
    cp r24, r20
    cpc r25, r21
    ret
    pusk:
    sbi portb,1
    rcall del_64
    sbi portd,7
    rcall del_64
    sbi portd,6
    rcall del_64
    sbi portd,5
    rcall del_64
    sbi portb,7
    rcall del_64
    sbi portb,6
    rcall del_64
    sbi portd,4
    rcall del_64
    sbi portd,3
    rcall del_64
    sbi portd,2
    rcall del_64
    sbi portd,1
    rcall del_64
    sbi portd,0
    rcall del_64
    sbi portc,5
    rcall del_64
    sbi portc,4
    rcall del_64
    sbi portc,3
    rcall del_64
    sbi portc,2
    rcall del_64
    sbi portc,1
    rcall del_64
    sbi portc,0
    rcall del_64
    sbi portb,5
    rcall del_64
    sbi portb,4
    rcall del_64
    sbi portb,3
    rcall del_64
    sbi portb,2
    rcall del_255
    cbi portb,2
    rcall del_128
    cbi portb,3
    rcall del_128
    cbi portb,4
    rcall del_128
    cbi portb,5
    rcall del_128
    cbi portc,0
    rcall del_128
    cbi portc,1
    rcall del_128
    cbi portc,2
    rcall del_128
    cbi portc,3
    rcall del_128
    cbi portc,4
    rcall del_128
    cbi portc,5
    rcall del_128
    cbi portd,0
    rcall del_128
    cbi portd,1
    rcall del_128
    cbi portd,2
    rcall del_128
    cbi portd,3
    rcall del_128
    cbi portd,4
    rcall del_128
    cbi portb,6
    rcall del_128
    cbi portb,7
    rcall del_128
    cbi portd,5
    rcall del_128
    cbi portd,6
    rcall del_128
    cbi portd,7
    rcall del_128
    cbi portb,1
    ret
    del_64:
    ldi r18,255
    ldi r19,24
    cyc_64:
    subi r18,1
    sbci r19,0
    brne cyc_64
    ret
    del_255:
    ldi r18,255
    ldi r19,180
    cyc_255:
    subi r18,1
    sbci r19,0
    brne cyc_255
    ret
    del_128:
    ldi r18,255
    ldi r19,100
    cyc_128:
    subi r18,1
    sbci r19,0
    brne cyc_128
    ret
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    I am sorry, due the lack of comments in the code It would take me far too long to work out.
    Thank
    Adam
